If you're having trouble printing maybe your security or firewall software is restricting data traffic through an essential port.
If you're having trouble installing or running a program, maybe your security or firewall software is blocking it.
See Table 1 for blocked ports or Table 2 for blocked programs.
1. Blocked ports
The following ports are necessary for your printer to function properly.
Unblock these ports in your security and firewall applications.
Port
Purpose
TCP 80
For HTTP communication
TCP / UDP 161
For SNMP communication (MAXIFY Printers)
TCP / UDP 162
TCP 443
For HTTPS communication such as cable-less setup operation (Applicable models only)
TCP / UDP 515
For printing using LPR protocol
TCP / UDP 9100
For printing using Raw protocol
TCP / UDP 1900
For Universal Plug and Play (UPnP) operation
TCP / UDP 5222
For Google Cloud Print and PIXMA Cloud Link
TCP / UDP 5357
For acquiring the printer information (WSDAPI)
TCP / UDP 8611
Canon BJNP port for printing
TCP / UDP 8612
Canon BJNP port for scanning (Applicable models only)
TCP / UDP 8613
Canon BJNP port for sending and receiving faxes from the PC (Applicable models only)
TCP 8883
For MQTT communication, such as for printers enrolled in the PIXMA Print Plan
UDP 3702
Windows 7 / Windows Vista
Ports Listed Below Apply Only to Models With Memory Card Slots
TCP / UDP 137
Memory card
TCP / UDP 138
Memory card
TCP / UDP 139
Memory card
2. Blocked programs
The following Windows and Macintosh® software programs are used with your Canon printer.
Check the settings of your security and firewall applications and make sure these programs aren't prevented from running or installing.
Program
Default Location
IJ Network Tool
Windows
C:\Program Files (x86)\Canon\Canon IJ Network Tool\CNMNPUT.EXE
Macintosh
/library/printers/canon/bjprinter/utilities/canon ij network tool.app
IJ Network Scan Utility
Windows
C:\Program Files (x86)\Canon\Canon IJ Network Scan Utilityl\CNMNSUT.EXE
Macintosh
/library/printers/canon/bjprinter/utilities/canon ij network scan utility.app
IJ Network Scanner Selector
Windows
N/A
Macintosh
/library/printers/canon/ijscanner/utilities/canon ij network scanner selector2.app
MP Navigator EX
Windows
C:\Program Files\Canon\MP Navigator EX**\ mpnex**.exe (** refers to version number)
Macintosh
/applications/canon utilities/mp navigator.app
My Image Garden
Windows
C:\Program Files (x86)\Canon\My Image Garden\cnmigmain.exe
Macintosh
/applications/canon utilities/my image garden.app
