Printing Out Network Setting Information
You can print out the network settings of the machine such as its IP address and SSID.
Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper.
Press the Setup button.
Select
Device settings, then press the OK button.
Use the
button to select LAN settings, then press the OK button.
Use the
button to select Confirm LAN settings, then press the OK button.
Use the
button to select Print LAN details, then press the OK button to confirm the selection.
Use the
button to select Yes, then press the OK button to start printing.
The machine starts printing the network setting information.
The following information on the machine's network setting is printed out.
Item | Explanations of the item | Setting |
Wireless LAN | Wireless LAN | Enable/Disable |
Link Status | Status of the Wireless LAN | Active/Inactive |
MAC Address | MAC Address | XX:XX:XX:XX:XX:XX |
SSID | SSID | SSID of the wireless LAN |
Connection Mode | Connection Mode | Infrastructure |
Channel | Channel | XX (1 to 13) |
Encryption | Method of the Encryption | none/WEP/TKIP/AES |
WEP Key Length | WEP Key Length | Inactive/128/64 |
Authentication | Method of the Authentication | none/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal Strength | 0 to 100 [%] |
TCP/IP Version | TCP/IP Version | IPv4/IPv6 |
IP Address | Selected IP Address | XXX.XXX.XXX.XXX |
Default Gateway | Default Gateway | XXX.XXX.XXX.XXX |
Subnet Mask*1 | Subnet Mask | XXX.XXX.XXX.XXX |
Subnet Prefix Length*2 | Subnet Prefix Length | XXX |
IPsec*3 | IPsec setting | Active |
Security Protocol*3 | Method of the Security Protocol | ESP/ESP & AH/AH |
Wired LAN | Wired LAN | Enable/Disable |
Link Status | Status of the Wired LAN | Active/Inactive |
IP Address | IP Address | XXX.XXX.XXX.XXX |
Printer Name | Printer name | Printer name (Up to 15 characters) |
Shared Memory Card | Memory card sharing | Enable/Disable |
WSD | WSD setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LLTD | LLTD setting | Enable/Disable |
LPR Protocol | LPR protocol setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 characters) |
Bonjour LPR Service | Bonjour LPR service advertising | Enable/Disable |
IP Address Filtering | IP Address Filtering | Enable/Disable |
("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
*1 Only when IPv4 is selected on IPv4/IPv6 setting, the status of the network is printed.
*2 Only when IPv6 is selected on IPv4/IPv6 setting, the status of the network is printed.
*3 Only when IPv6 is selected on IPv4/IPv6 setting and Active is selected on IPsec settings, the status of the network is printed.
Page top
