You can print out the network settings of your machine such as its IP address, network name (SSID), Encryption, and more.
Print out network configurations
To print the wireless network (LAN) settings:
Sample page
Item | Explanations of the Item | Setting |
Wireless LAN | Wireless LAN | Enable/Disable |
Link Status | Status of the Wireless LAN | Active/Inactive |
Mac® Address | Mac Address | XX:XX:XX:XX:XX:XX |
SSID | SSID | SSID of the wireless LAN |
Connection Mode | Connection Mode | Infrastructure |
Channel | Channel | XX (1 to 13) |
Encryption | Method of the Encryption | none/WEP/TKIP/AES |
WEP Key Length | WEP Key Length | Inactive/128/64 |
Authentication | Method of the Authentication | none/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal Strength | 0 to 100 [%] |
TCP/IP Version | TCP/IP Version | IPv4/IPv6 |
IP Address | Selected IP Address | XXX.XXX.XXX.XXX |
Default Gateway | Default Gateway | XXX.XXX.XXX.XXX |
Subnet Mask*1 | Subnet Mask | XXX.XXX.XXX.XXX |
Subnet Prefix Length*2 | Subnet Prefix Length | XXX |
IPsec*3 | IPsec setting | Active |
Security Protocol*3 | Method of the Security Protocol | ESP/ESP & AH/AH |
WPS PIN CODE | WPS PIN CODE | XXXXXXXX (Up to 8 characters) |
Printer Name | Printer name | Printer name (Up to 15 characters) |
WSD | WSD setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LLTD | LLTD setting | Enable/Disable |
LPR Protocol | LPR protocol setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 48 characters) |
Bonjour LPR Service | Bonjour LPR service advertising | Enable/Disable |
IP Address Filtering | IP Address Filtering | Enable/Disable |
Additional table details:
X - represents an alphanumeric character ranging from 0 to 9 and A to F.
*1 - Only when the TCP/IP version is IPv4, the status of the network is printed.
*2 - Only when the TCP/IP version is IPv6, the status of the network is printed.
- *3 - Only when the TCP/IP version is IPv6 and the IP sec setting is activated, the status of the network is printed.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
