Salesforce
Accessing, changing or printing the LAN settings (MX860)
« Go Back
Information
TitleAccessing, changing or printing the LAN settings (MX860)
URL NameART114060
Description
When you change the connection method (wired or wireless), set up the machine according to the method you will use. For details, refer to your setup manual.
Solution
Accessing, Changing or Printing the LAN Settings
This section describes the procedure to change the settings in the Device settings screen, taking the steps to specify Extended copy amount as an example.
  1. Make sure that the machine is turned on, then press the Menu button.
  2. Use the button to select Settings, then press the OK button.
  3. Use the button to select Device settings, then press the OK button.
    The Device settings screen is displayed.
  4. Use the button to select LAN Settings, then press the OK button.
  5. Use the button to select a LAN settings option, then press the OK button.
    The setting screen for the selected item is displayed.
  6. Use the button to select Yes, then press the OK button.
LAN settings
  • Change WLAN/LAN
    Activates either wireless LAN or wired LAN. You can also deactivate wireless/wired LAN.
    Note
    • When you change the connection method (wired or wireless), set up the machine according to the method you will use. For details, refer to your setup manual.
  • WLAN settings
    Selects the setting method for wireless LAN connection.
    • WPS setting
      Select when you perform settings for wireless LAN using Wi-Fi Protected Setup (WPS). Select Push button method or PIN code method according to the method your access point supports, then follow the on-screen instructions.
    • WCN setting
      Select when you perform settings for wireless LAN using Windows Connect Now (WCN) feature. You need a USB flash drive on which settings for wireless LAN are saved.
  • WLAN setting list
    The list of wireless/wired LAN settings of this machine is displayed on the LCD.
    You can print the list from this setting menu.
  • Items
    Setting (IPv4)
    Setting (IPv6)
    Connection
    Active/Inactive
    Active/Inactive
    SSID
    XXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXX
    Communication mode
    Infrastructure
    Infrastructure
    Channel
    XX
    XX
    Data encryption
    Disable/WEP/TKIP/AES
    Network authentication
    Auto/Open system/Shared key/WPA-PSK/WPA2-PSK
    WEP bit
    Disable/128/64
    Disable/128/64
    IP address
    XXX. XXX. XXX. XXX
    XXX. XXX. XXX. XXX.
    XXX. XXX. XXX. XXX
    Subnet mask
    XXX. XXX. XXX. XXX
    Subnet prefix length
    XXX
    Default gateway
    XXX. XXX. XXX. XXX
    XXX. XX. XXX. XXX
    MAC address
    XX:XX:XX:XX:XX:XX
    XX:XX:XX:XX:XX:XX
    IPsec settings
    Active/Inactive
    Security protocol
    ESP/ESP & AH/AH
    Pre-shared key
    XXXXXXXXXXX
    ("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
  • LAN setting list
    The list of wired LAN settings of this machine is displayed on the LCD.
    The following setting items are displayed.
Items
Setting (IPv4)
Setting (IPv6)
Connection
Active/Inactive
Active/Inactive
IP address
XXX. XXX. XXX. XXX
XXX. XXX. XXX. XXX.
XXX. XXX. XXX. XXX
Subnet mask
XXX. XXX. XXX. XXX
XXX
Default gateway
XXX. XXX. XXX. XXX
XXX. XXX. XXX. XXX
MAC address
XX:XX:XX:XX:XX:XX
XX:XX:XX:XX:XX:XX
IPsec settings
Active/Inactive
Security protocol-ESP/ESP & AH/AH
Pre-shared key
XXXXXXXXXXX
  • IPv4/IPv6 setting
    Selects the IP version (IPv4 or IPv6). It is recommended to use the machine with IPv4.
  • WSD setting
    Activates/deactivates the WSD (one of the network protocols supported in Windows 7 and Windows Vista) setting.
    Note
    • When you set WSD setting to Enable, the printer icon is displayed on the Network Explorer in Windows 7 and Windows Vista.
  • Print LAN details
    You can print out the network settings of the machine such as its IP address and SSID.
    Important
    This print out contains valuable information about your computer. Handle it with care.
  • Reset LAN settings
    Initializes the network settings on the machine.
    Important
    • Note that initialization erases all connection settings with computers, and printing or scanning operation may become impossible. To use the machine over network, refer to your setup manual. Be careful when you initialize the network settings on the machine.
Powered by
