Wireless Setup Using WPS (Wi-Fi Protected Setup)
Before Starting Wireless Connection Setup
REFERENCE
Make sure that the printer is turned on.
If the power is on, the (white) POWER lamp (A) will be lit.
1. Make sure that the button on the wireless router is ready to be pressed.
2. Hold down the Wi-Fi button (B) on the printer until the (white) POWER lamp flashes once, then release the Wi-Fi button after the flash.
3. When the (blue) Wi-Fi lamp flashes quickly and the (white) POWER lamp is lit as shown in the illustration below, press and hold the button on the wireless router within one minute and thirty seconds.
4. Make sure that the (blue) Wi-Fi lamp and the (white) POWER lamp are lit.
REFERENCE
If the (orange) Alarm lamp lights up, see "If the Alarm lamp lights up" below in this page and follow the instructions there.
The wireless LAN setup using WPS is completed.
Install the software.
- When the (blue) Wi-Fi lamp flashes slowly and the (orange) Alarm lamp is lit.
After checking the below points, wait for a while and configure wireless connection setting again.
- Press the button on only one wireless router.
- Check the security settings of the wireless router.
- When the (blue) Wi-Fi lamp flashes quickly and the (orange) Alarm lamp is lit.
Is the network device (router, etc.) turned on? If the network device is already turned on, turn it off, then turn it back on.
- If the (orange) Alarm lamp still lights up.
- Are the computer and network device configured?
- Are the wireless router and printer installed in an open space where wireless communications are possible?
- Is the wireless router operating in IEEE802.11n (2.4 GHz), IEEE802.11g or IEEE802.11b?
