Before installing the software To use your printer via wireless LAN connection, you need to complete the printer settings for wireless LAN connection before installing the software. Windows IMPORTANT - Quit all applications before installation.
- Log on using an administrator account.
- Internet connection may be required during the installation. Connection fees apply.
1. Insert the CD-ROM into the computer. REFERENCE If your computer does not have the CD-ROM drive or you do not have the Setup CD, follow the steps given below. - Visit http://canon.com/ijsetup/.
- Select your region, printer name, and computer OS.
- In the Product Setup section, click Download. The setup file will be downloaded.
- Double-click the downloaded .exe file.
The setup will start automatically. Go to Step 3 and follow the instructions.
2. Click [ Run Msetup4.exe ] on the AutoPlay screen, then click [ Yes ] or [ Continue ] on the User Account Control dialog box. If the User Account Control dialog box reappears in following steps, click [ Yes ] or [ Continue ]. REFERENCE If the CD-ROM does not autorun: Double-click [ (My) Computer ] > CDROM icon > [ MSETUP4.EXE. ]
3. Click [ Next ]. REFERENCE When the .NET Framework screen appears, click [Yes].
4. Click [ Next ]. REFERENCE Easy-WebPrint EX is Web print software that is installed on the computer when installing the supplied software. Internet Explorer 7 or later (Windows) is required to use this software. An Internet connection is required for installation.
Follow any on-screen instructions to proceed with the software installation. 5. When the Setup Completion dialog box appears, click [ Complete ]. 6. Click [ Next ]. - Important Information for the installation - If the Extended Survey Program screen appears
If you can agree to Extended Survey Program, click [ Agree ]. If you click [ Do not agree ], the Extended Survey Program will not be installed. (This has no effect on the machine's functionality.) - When the Test Print window is displayed
Test printing will be performed to check the printer's operation. Load plain paper into the printer and click [ Execute ]. After test printing, click [ Next ]. To skip test printing, click [ Next ] instead of [ Execute ]. 7. Click [ Exit ] to complete the installation. Remove the Setup CD-ROM and keep it in a safe place. 8. Quick Menu starts. The software is installed in your Windows computer. Mac OS X IMPORTANT - Quit all applications before installation.
2. Select your region, printer name, and computer OS. 3. In the Product Setup section, click [ Download ]. The setup file will be downloaded. 4. Double-click the downloaded .dmg file. 5. Double-click the [ Setup ] icon. 6. Click [ Next ]. 7. In the subsequent screen, enter the administrator name and password. Then click [ Install Helper ]. 8. Click [ Next ]. 9. Click [ Next ]. Follow any on-screen instructions to proceed with the software installation. 10. Click [ Add Printer ]. REFERENCE - The alphanumeric characters after "Canon xxx series" is the machines Bonjour service name or MAC address.
- If the machine is not detected, make sure of the following.
- The machine is turned on. - The firewall function of any security software is turned off. - The computer is connected to the access point.
11. Select [ Canon xxx series Canon IJ Network ] and click [ Add ]. CAUTION If you will be installing the Canon printer driver on Mac OS X and using the printer through a network connection, you can select [ Bonjour ] or [ Canon IJ Network ] in the [ Add Printer ] dialog. If [ Bonjour ] is selected, remaining ink level messages may differ from those indicated by [ Canon IJ Network ]. Canon recommends you to use [ Canon IJ Network ] for printing.
12. Click [ Next ]. 13. Click [ Next ]. - Important Information for the installation - If the Extended Survey Program screen appears
Test printing will be performed to check the printer's operation. Load plain paper into the printer and click [ Execute ]. After test printing, click [ Next ]. To skip test printing, click [ Next ] instead of [ Execute ]. 14. Click [ Exit ] to complete the installation. Remove the Setup CD-ROM and keep it in a safe place. 15. Quick Menu starts. The software is installed in your Mac OS X computer. |
