Solution | Wireless Setup Using WPS (Wi-Fi Protected Setup) Before Starting Wireless Connection Setup
Note - Make sure that the printer is turned on.
 - Make sure that the button on the wireless router / access point is ready to be pressed.
- Hold down the Wi-Fi button (A) on the printer until the Alarm lamp (B) flashes once, then release the Wi-Fi button after the flash.
 - Make sure the Wi-Fi lamp (C) flashes quickly and the POWER lamp (D) is lit as shown below, and press and hold the button on the access point within 2 minutes.
 - Make sure that the Wi-Fi lamp and the POWER lamp are lit.
Note - If the (orange) Alarm lamp lights up, see "If the Alarm lamp lights up" below in this page and follow the instructions there.
The wireless LAN setup using WPS is completed. Install the software. If the Alarm lamp lights up - When the Wi-Fi lamp flashes slowly and the Alarm lamp is lit.
 After checking the points described below, wait for a while and configure wireless connection settings again. - Press the button on only one wireless router / access point.
- Check the security settings of the wireless router / access point.
- When the Wi-Fi lamp flashes quickly and the Alarm lamp is lit.
 Is the network device (router, etc.) turned on? If the network device is already turned on, turn it off, then turn it back on. - If the Alarm lamp still lights up.
After checking the points described below, wait for a while and configure wireless connection settings again. - Are the computer and network device configured?
- Are the wireless router / access point and printer installed in an open space where wireless communications are possible?
- Is the wireless router / access point operating in IEEE802.11n (2.4 GHz), IEEE802.11g or IEEE802.11b?
