Salesforce
How to Print LAN Settings - iX6820
« Go Back
Information
TitleHow to Print LAN Settings - iX6820
URL NameART117142
Description
This article explains how to print the LAN details page for the PIXMA iX6820. An example of this page can be found here.
Solution
You can print out the network settings of the printer such as its IP address and SSID.
 This print out contains valuable information about your computer. Handle it with care.
  1. Make sure that the printer is turned on.
  2. Load a sheet of A4 or Letter-sized plain paper.
  3. Press and hold the RESUME/CANCEL button, then release the button when the POWER lamp flashes white 6 times.
    The printer starts printing the network setting information.
    The following information on the printer's network setting is printed out.
    Item
    Explanations of the item
    Setting
    Wireless LAN
    Wireless LAN
    Enable/Disable
    Connection
    Status of the Wireless LAN
    Active/Inactive
    MAC Address
    MAC Address
    XX:XX:XX:XX:XX:XX
    SSID
    SSID
    SSID of the wireless LAN
    Communication Mode
    Communication Mode
    Infrastructure
    Channel
    Channel
    XX (1 to 13)
    Encryption
    Method of the Encryption
    none/WEP/TKIP/AES
    WEP Key Length
    WEP Key Length
    Inactive/128/64
    Authentication
    Method of the Authentication
    none/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal Strength
    0 to 100 [%]
    TCP/IP Version
    TCP/IP Version
    IPv4 & IPv6/IPv4
    IPv4 IP Address
    Selected IP Address (IPv4)
    XXX.XXX.XXX.XXX
    IPv4 Default Gateway
    Default Gateway (IPv4)
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet Mask
    XXX.XXX.XXX.XXX
    IPv6 IP Address *1
    Selected IP Address (IPv6)
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPv6 Default Gateway *1
    Default Gateway (IPv6)
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Subnet Prefix Length*1
    XXX
    IPsec*2
    IPsec setting
    Active
    Security Protocol*2
    Method of the Security Protocol
    ESP/ESP & AH/AH
    WPS PIN CODE
    WPS PIN code
    XXXXXXXX
    Wireless LAN DRX
    Discontinuous reception (wireless LAN)
    Enable/Disable
    Wired LAN
    Wired LAN
    Enable/Disable
    Connection
    Status of the Wired LAN
    Active/Inactive
    MAC Address
    MAC Address
    XX:XX:XX:XX:XX:XX
    TCP/IP Version
    TCP/IP Version
    IPv4 & IPv6/IPv4
    IPv4 IP Address
    XXX.XXX.XXX.XXX
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet Mask
    XXX.XXX.XXX.XXX
    IPv6 IP Address *1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    IPsec*2
    IPsec setting
    Active
    Security Protocol*2
    ESP/ESP & AH/AH
    Wired LAN DRX
    Discontinuous reception (wired LAN)
    Enable/Disable
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 characters)
    WSD
    WSD setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPR Protocol
    LPR protocol setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 characters)
    DNS Server
    Getting DNS Server automatically
    Auto/Manual
    Primary Server
    Primary server address
    XXX.XXX.XXX.XXX
    Secondary Server
    Secondary server address
    XXX.XXX.XXX.XXX
    Proxy Server
    Proxy Server setting
    Enable/Disable
    Proxy Port
    Specifying Proxy Port
    1 to 65535
    Proxy Address
    Proxy Address
    XXXXXXXXXXXXXXXXXXXX
    IP Address Filtering
    Enable/Disable
    Default Password*3
    Default Administrator Password
    XXXXXXXX
    ("XX" represents alphanumeric characters.)
    *1 Only when IPv6 is activated, the status of the network is printed.
    *2 Only IPv6 and the IPsec setting are activated, the status of the network is printed.
    *3 On firmware version 3.000 or later.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
Powered by
