Salesforce
Automatically Aligning the Print Head (Windows) - MG3500 Series / MG3620
« Go Back
Information
TitleAutomatically Aligning the Print Head (Windows) - MG3500 Series / MG3620
URL NameART117423
Description
Learn how to automatically align the print head of the PIXMA MG3500 Series / MG3620 from a Windows PC. If lines are misaligned / text is not straight, aligning the print head may resolve the problem.
Solution
Print head alignment corrects the installation positions of the print head and improves deviated colors and lines.
This machine supports two head alignment methods: automatic head alignment and manual head alignment. Normally, the machine is set for automatic head alignment. If the printing results of automatic print head alignment are not satisfactory, perform manual head alignment.
The procedure for performing automatic print head alignment is as follows:
Print Head Alignment
  1. Open the printer driver setup window
  2. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  3. Load paper in the machine
    Load one sheet of A4 size or Letter size plain paper into the front tray.
    Note
    • The number of sheets to be used differs when you select the manual head alignment.
  4. Print head alignment pattern printing
    Make sure that the machine is on and click Align Print Head.
    The adjustment pattern is printed.
    Important
    • Do not open the paper output cover while printing is in progress.
  5. Adjustment pattern scanning
    After the adjustment pattern is printed, a message is displayed.
    As instructed in the message, load the adjustment pattern onto the platen, and press the Start button on the machine.
    Print head alignment starts.
Note
  • To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Powered by
