Commercially Available Papers
Media Name | Front Tray | Paper Output Tray |
Plain Paper (including recycled paper)*1 | - 100 sheets
| - 50 sheets
Envelopes | 5 envelopes | *2 |
Canon Genuine Papers
Note We recommend that you remove the previously printed sheet from the paper output tray before continuously printing to avoid blurs and discoloration (except for High Resolution Paper <HR-101N>).
Paper for printing photos:
Media Name <Model No.> | Front Tray |
Photo Paper Pro Platinum <PT-101>*3 | 10 sheets: A4, Letter, and 8" x 10" (20 x 25 cm) 20 sheets: 4" x 6" (10 x 15 cm) |
Glossy Photo Paper "Everyday Use" <GP-501>*3 | 10 sheets: A4 and Letter 20 sheets: 4" x 6" (10 x 15 cm) |
Photo Paper Glossy <GP-502>*3 | 10 sheets: A4 and Letter 20 sheets: 4" x 6" (10 x 15 cm) |
Photo Paper Plus Glossy II <PP-201>*3 | 10 sheets: A4, Letter, 5" x 7" (13 x 18 cm), and 8" x 10" (20 x 25 cm) 20 sheets: 4" x 6" (10 x 15 cm) |
Photo Paper Pro Luster <LU-101>*3 | 10 sheets: A4 and Letter |
Photo Paper Plus Semi-gloss <SG-201>*3 | 10 sheets: A4, Letter, 5" x 7" (13 x 18 cm), and 8" x 10" (20 x 25 cm) 20 sheets: 4" x 6" (10 x 15 cm) |
Matte Photo Paper <MP-101> | 10 sheets: A4 and Letter 20 sheets: 4" x 6" (10 x 15 cm) |
Paper for printing business documents:
Media Name <Model No.> | Front Tray | Paper Output Tray |
High Resolution Paper <HR-101N> | 80 sheets | 50 sheets |
Paper for creating your own prints:
T-Shirt Transfers <TR-301> | 1 sheet |
Photo Stickers <PS-101> | 1 sheet |
*1 Proper feeding of paper may not be possible at the maximum capacity depending on the type of paper or environmental conditions (either very high or low temperature or humidity). In such cases, reduce the number of paper you load at a time to less than half.
*2 We recommend that you remove the previously printed envelope from the paper output tray before continuously printing to avoid blurs and discoloration.
*3 When loading paper in stacks, the print side may become marked as it is fed or paper may not feed properly. In this case, load one sheet at a time.
Page top
