How to print out the network settings information - MP640 / MP640R
URL Name
ART135862
Description
This article explains how to print out the network setting information (LAN details) for the PIXMA MP640 / MP640R. An example of this information is attached to the bottom of this article.
Solution
You can print out the network settings of the machine such as its IP address and SSID.
Important
This print out contains valuable information about your computer. Handle it with care.
Make sure that the machine is turned on.
Load a sheet of A4 or Letter-sized plain paper in the Cassette.
Select
Settings on the HOME screen, then press the OK button.
Select
Device settings, then press the OK button.
Select LAN settings, then press the OK button.
Select Confirm LAN settings, then press the OK button.
Select Print LAN details, then press the OK button.
Select Yes, then press the OK button.
The following information on the machine's network setting is printed out.
Item
Explanations of the item
Setting
Wireless LAN
Wireless LAN
Enable/Disable
Link Status
Status of the Wireless LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID
SSID of the wireless LAN
Connection Mode
Connection Mode
Infrastructure
Channel
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal Strength
0 to 100 [%]
TCP/IP Version
TCP/IP Version
IPv4/IPv6
IP Address
Selected IP Address
XXX.XXX.XXX.XXX
Default Gateway
Default Gateway
XXX.XXX.XXX.XXX
Subnet Mask*1
Subnet Mask
XXX.XXX.XXX.XXX
Subnet Prefix Length*2
XXX
IPsec*3
IPsec setting
Active
Security Protocol*3
Method of the Security Protocol
ESP/ESP & AH/AH
Wired LAN
Wired LAN
Enable/Disable
Link Status
Status of the Wired LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
TCP/IP Version
TCP/IP Version
IPv4/IPv6
IP Address
IP Address
XXX.XXX.XXX.XXX
Default Gateway
Default Gateway
XXX.XXX.XXX.XXX
Subnet Mask*1
Subnet Mask
XXX.XXX.XXX.XXX
XXX
IPsec*3
IPsec setting
Active
Security Protocol*3
ESP/ESP & AH/AH
Printer Name
Printer name
Printer name (Up to 15 characters)
Shared Memory Card
Memory card sharing
Enable/Disable
WSD
WSD setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LLTD
LLTD setting
Enable/Disable
LPR Protocol
LPR protocol setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
Bonjour LPR Service
Bonjour LPR service advertising
Enable/Disable
("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
*1 Only when IPv4 is selected on IPv4/IPv6 settings, the status of the network is printed.
*2 Only when IPv6 is selected on IPv4/IPv6 settings, the status of the network is printed.
*3 Only when IPv6 is selected on IPv4/IPv6 settings and Active is selected on IPsec Settings, the status of the network is printed.
