Solution | Check the LAN Settings-
Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper. -
Press the Menu button -
Select Setup , then press the OK button. -
Select
Device settings, then press the OK button. -
Use the
button to select LAN settings, then press the OK button. -
Use the
button to select Confirm LAN settings, then press the OK button. -
Use the
button to select Print LAN details, then press the OK button to confirm the selection. -
Use the
button to select Yes, then press the OK button to start printing. The machine starts printing the network setting information.
