Solution |
Check the LAN Settings
Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper
Select Setup on the HOME screen Select Device settings, then touch the OK button. Use the  button to select LAN settings, then touch the OK button. Use the  button to select Confirm LAN settings, then touch the OK button. Use the  button to select Print LAN details, then touch the OK button to confirm the selection.
Use the  button to select Yes, then touch the OK button to start printing.
The machine starts printing the network setting information.
