Salesforce
Save Dialog Box (Scan View) - My Image Garden (Windows)
« Go Back
Information
TitleSave Dialog Box (Scan View) - My Image Garden (Windows)
URL NameART135923
Description
Solution
You can make advanced settings for saving scanned images to a computer.
Click Save at the bottom right of the Scan view to display the Save dialog box.
figure: Save dialog box (Scan view)
Save in
Displays the folder in which to save the scanned images. To change the folder, click Browse..., then specify the destination folder.
The default save folders are as follows.
Windows 7: My Pictures folder
Windows Vista: Pictures folder
Windows XP: My Pictures folder
File Name
You can enter the file name of the image to be saved. You cannot enter the file name when saving multiple files at the same time. They will be saved with the file names automatically generated after scanning.
Data Format
You can specify the data format in which to save the scanned images.
You can select JPEG, TIFF, PNG, PDF, PDF (Add Page), PDF (Multiple Pages) or Save in the original data format.
When PDF (Add Page) is selected, click Specify Location... in the displayed message, then specify the PDF file to which to insert the images.
Note
  • PDF (Multiple Pages) appears only when multiple images are selected in the Scanned Image Thumbnails area of the Scan view.
  • Save in the original data format appears only when multiple data formats are selected in the Scanned Image Thumbnails area of the Scan view.
Settings...
You can make more advanced save settings when JPEG, PDF, PDF (Add Page) or PDF (Multiple Pages) is selected in Data Format.
When JPEG is selected
The File Settings dialog box appears and you can specify the image quality (compression type) of JPEG files. You can select High (Low Compression), Standard or Low (High Compression).
When PDF, PDF (Add Page) or PDF (Multiple Pages) is selected
The PDF Settings dialog box appears and you can make advanced settings for creating PDF files.
Save to a subfolder with current date
Select this checkbox to create a current date folder in the folder specified in Save in and save scanned images in it. The folder will be created with a name such as "20XX_01_01" (Year_Month_Date).
If this checkbox is not selected, files are saved directly in the folder specified in Save in.
Powered by
