Salesforce
Scan Documents Using the IJ Scan Utility - Windows
« Go Back
Information
TitleScan Documents Using the IJ Scan Utility - Windows
URL NameART137998
Description
Learn how to easily scan your documents and photos with the Auto Scan function of the IJ Scan Utility tool on your Windows computer.
Solution
Before you begin
IJ Scan Utility is installed when the MP Drivers for your product have been installed.
Tip If you don't see IJ Scan Utility in the Start menu, you can find it here: C:\Program Files (x86)\Canon\IJ Scan Utility\SCANUTILITY.EXE
If the IJ Scan Utility is not installed on your computer, instructions to obtain the IJ Scan Utility can be found here.
Tip If you have a Mac®, instructions to obtain the IJ Scan Utility can be found here. Please note that depending on your product, the IJ Scan Utility may be bundled with the scanner driver.
How to use Auto Scan
  Video Watch the video to learn how to scan documents using the IJ Scan Utility for Windows or follow the written instructions below.
Written Instructions
Follow these steps to scan:
  1. Make sure that your scanner or printer is turned on.
  2. Place originals on the platen glass scanning surface.
  3. Launch IJ Scan Utility on your computer.
  4. Select Auto to start scanning.
Note You can select Cancel to stop the scan.
Image of the IJ Scan Utility navigation screen
  1. Your scanned image is saved in the folder you've specified in Settings... > Settings (Auto Scan).
Good to know
Types of items that may not scan correctly
  • This includes photos with a white-ish background, items printed on white paper, thin or thick items, hand-written documents, business cards, etc.
  • You can correct this by adjusting the scan areas in whole image view of the scanner driver ScanGear, then rescanning the original document or photo.
Image corrections
  • To apply image corrections based on the item type, go to Settings... > Settings (Auto Scan) and select Apply recommended image correction.
  • Refer to About Auto Scan settings for more about image corrections.
Scanning specific types of media
Powered by
