Salesforce
How to print out the LAN settings - MX512
« Go Back
Information
TitleHow to print out the LAN settings - MX512
URL NameART138034
Description
Solution
Check the LAN Settings
  1. Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper.
  2. Press the Menu button
  3. Select Setup     , then press the OK button.
  4. Select Device settings, then press the OK button.
  5. Use the UP DOWN button to select LAN settings, then press the OK button.
  6. Use the UP DOWN button to select Confirm LAN settings, then press the OK button.
  7. Use the UP DOWN button to select Print LAN details, then press the OK button to confirm the selection.
  8. Use the UP DOWN button to select Yes, then press the OK button to start printing.
    The machine starts printing the network setting information.  An example page is included below.
Powered by
