Display the Data Format Settings dialog box by one of the following operations.
Click Settings... of Save Settings on each tab of the Settings dialog box
Click Settings... of Save Settings in the Save Settings dialog box that appears after scanning with the Check scan results checkbox selected in the Settings dialog box
In the Data Format Settings dialog box, you can set the quality of the images to be saved, keyword search of PDF files and their compression type, and the data format in which to save images scanned with Auto Scan.
The IJ Scan Utility requires My Image Garden to be installed to have the Searchable PDF option.
JPEG Image Quality
You can specify the image quality of JPEG files.
Important -
Create a PDF file that supports keyword search
Select this checkbox to convert text in images into text data and create PDF files that support keyword search.
PDF Compression
Select the compression type for saving PDF files.
Standard
It is recommended that you normally select this setting.
High
Compresses the file size when saving, allowing you to reduce the load on your network/server.
Note -
Format for Item Detected as Document in Auto Scan
You can specify the data format for automatically saving items detected as documents in Auto Scan.
Format for Item Detected as Photo in Auto Scan
You can specify the data format for automatically saving items detected as photos in Auto Scan.
Defaults
You can restore the settings in the displayed screen to the default settings.
