Salesforce
How to print out the LAN settings - MG6220
« Go Back
Information
TitleHow to print out the LAN settings - MG6220
URL NameART138107
Description
This article explains how to print a Network Configuration Page for the PIXMA MG6220.  An example of this page is attached to this article.
Solution
Check the LAN Settings
  1. Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper
  2. Select Setup on the HOME screen
  3. Select Device settings, then touch the OK button.
  4. Use the UP DOWN button to select LAN settings, then touch the OK button.
  5. Use the UP DOWN button to select Confirm LAN settings, then touch the OK button.
  6. Use the UP DOWN button to select Print LAN details, then touch the OK button to confirm the selection.
  7. Use the UP DOWN button to select Yes, then touch the OK button to start printing.
    The machine starts printing the network setting information.
Powered by
