You can load European DL and US #10 envelopes.
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
Important Do not use the following envelopes. They could jam in the printer or cause the printer to malfunction.
- Envelopes with an embossed or treated surface - Envelopes with a double flap - Envelopes whose gummed flaps are already moistened and adhesive |
Prepare envelopes.
Press down on all four corners and edges of the envelopes to flatten them.
If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
If the corner of the envelope flap is folded, flatten it.
Important The envelopes may jam in the printer if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm).
Do not flatten the leading edge of envelopes. Otherwise, the printing position may shift out of place.
Load envelopes.
(1) Pull out the cassette (lower) from the printer.
(2) Slide the paper guide (A) in front and (B) on the right to open the guides.
(3) Load the envelopes WITH THE PRINT SIDE FACING DOWN, and place them in the center of the cassette (lower).
The folded flap of the envelope will be faced up on the left side.
(C) Rear side
(D) Address side
Up to 10 envelopes can be loaded at once.
Note Align the envelope stack with the edge of the cassette (lower) as shown in the figure below.
If the envelopes are in contact with the protrusion (E), the envelopes may not be fed properly. |
(4) Align the paper guide (A) in front with the envelopes.
(5) Slide the paper guide (B) on the right to align the right and left guides with sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Note Do not load envelopes higher than the load limit mark (F).
Keep the envelope stack height below the tabs (G) of the paper guides.
(6) Insert the cassette (lower) into the printer.
Push the cassette (lower) into the printer until it stops.
Open the paper output tray.
(1) Press the open button (H) to open the paper output tray.
The output tray extension opens automatically when the paper output tray is opened.
(2) Extend the paper output support.
Note After loading envelopes Select the size and type of the loaded envelopes on the print settings screen of the printer driver.
Page top
