Salesforce
Print Out Wireless Network Details - PIXMA MG3520, MG3522
« Go Back
Information
TitlePrint Out Wireless Network Details - PIXMA MG3520, MG3522
URL NameART141334
Description
Learn how to print a Network Configuration Page (wireless network settings) for your PIXMA MG3520 and MG3522.
Solution
Follow the steps below to print out the wireless network settings for your PIXMA printer, including its IP address and network name.
Caution This printout contains valuable information about your computer. Handle it with care.
Print out the network settings
  1. Turn the printer ON.
  2. Load a sheet of A4 or Letter-sized plain paper into the tray.
  3. Press and hold the Stop button until the Alarm lamp flashes 15 times, then release the button.
A sheet prints with network information similar to what you see below.
Sample printout
Item
Explanations of the item
Setting
Wireless LAN
Wireless LAN
Enable/Disable
Connection
Status of the Wireless LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID
SSID (network name) of the wireless LAN
Communication Mode
Communication Mode
Infrastructure
Channel
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal Strength
0 to 100 [%]
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
Selected IP Address (IPv4)
XXX.XXX.XXX.XXX
IPv4 Default Gateway
Default Gateway (IPv4)
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *1
Selected IP Address (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
IPv6 Default Gateway *1
Default Gateway (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Subnet Prefix Length*1
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
Method of the Security Protocol
ESP/ESP & AH/AH
WPS PIN CODE
WPS PIN code
XXXXXXXX
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable/Disable
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 characters)
WSD
WSD setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
DNS Server
Getting DNS Server automatically
Auto/Manual
Primary Server
Primary server address
XXX.XXX.XXX.XXX
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
Proxy Server
Proxy Server setting
Enable/Disable
Proxy Port
Specifying Proxy Port
1 to 65535
Proxy Address
Proxy Address
XXXXXXXXXXXXXXXXXXXX
IP Address Filtering
Enable/Disable
("XX" represents alphanumeric characters.)
*1 The status of the network prints only when IPv6 is activated.
*2 The status of the network prints only when IPv6 and the IPsec settings are activated.
Powered by
