The print head cleaning function allows you to clear up clogged print head nozzle. Perform print headcleaning if printing is faint or a specific color fails to print, even though there is enough ink.
The procedure for cleaning the print head is as follows:
Cleaning
Open the printer driver setup window
Click Cleaning on the Maintenance tab
When the Print Head Cleaning dialog box opens, select the ink group for which cleaning is to be performed.
Click Initial Check Items to display the items you need to check before performing cleaning.
Execute cleaning
Make sure that the printer is on and then click Execute.
Print head cleaning starts.
Complete cleaning
The Nozzle Check dialog box opens after the confirmation message.
Check the results
To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
If cleaning the head once does not resolve the print head problem, clean it once more.
Important
Deep Cleaning
Deep Cleaning is more thorough than cleaning. Perform deep cleaning when two Cleaning attempts do not resolve the print head problem.
Click Deep Cleaning on the Maintenance tab
When the Deep Cleaning dialog box opens, select the ink group for which deep cleaning is to be performed.
Click Initial Check Items to display the items you need to check before performing deep cleaning.
Execute deep cleaning
Click OK when the confirmation message appears.
Print head deep cleaning starts.
Complete deep cleaning
Check the results
Important
Note
If there is no sign of improvement after Deep Cleaning, switch off the printer, wait 24 hours, and then perform Deep Cleaning again. If there is still no sign of improvement, the ink may have run out or the print head may be worn.
