Before Starting
Depending on the iOS device you are using, the interface may look slightly different than the images in this article.
To print a document in Canon PRINT, follow the steps below.
From the main screen, tap Document Print.
Select Documents or Cloud Services. In this example, Documents will be selected.
Recently saved PDF files will be shown.
You can tap one of these files, or you can tap Browse to specify a location where a document is saved.
Tap Browse at the upper left to specify if you want to specify a location in your iCloud Drive or on your device.
Specify a location where you have a document saved. In this example, On My iPhone will be selected.
Browse through the folders displayed. You can sort the folders by Name, Date, Size, or Tags.
If you tap the ellipsis (the three dots in the circle), you can specify how you want to sort the displayed items (by name, date, size, kind, or tags). You can also create a subfolder in the folder you're currently browsing through.
In this example, tap PRINT, then Documents.
Tap on the document that you want to print.
For steps on deleting a previously scanned document, click here.
The document will appear on the screen. Tap Next.
On the Print screen, you can tap Change settings to change your print options, or you can tap Print.
Your document will be printed.
If you wish to open a saved document in another app, click here.
Tapping
will take you back to the main screen.
Deleting a Scanned Document
If you want to delete a document that you scanned in previously, open the Files app on your device. Navigate to the document in question, tap and hold on the icon for the document for 3 seconds, then let go. A menu will appear on the screen. Tap Delete.
The document is now deleted.
Open a Document in Another App
If you want to use another app to open a document that you scanned in previously, tap the Share
icon in Step 6 above. Several options will appear. Select an app that you wish to use to open the document (Books is used in this example).
After tapping Books as shown in the screen above, this PDF will open in the Books app.
The apps you can select will vary depending on what is installed on your iOS device.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
