Salesforce
Paper Jam Inside the Printer - PIXMA MG3620
« Go Back
Information
TitlePaper Jam Inside the Printer - PIXMA MG3620
URL NameART162611
Description
Learn how to remove a paper jam from inside of the PIXMA MG3620.
Solution
Watch this video or review the written steps below to learn how to remove a paper jam.
Written Steps
If the jammed paper tears and portions remain in the machine, follow this process to remove it:
  1. Press Stop to cancel the print job.
  2. Turn off the machine and unplug the power cord.
  3. Open the paper output cover.
    paper output cover in open position
  4. Remove any paper from the front tray.
    Caution Don't touch the clear film (A). The machine can be damaged if the paper or your hands touch the clear film and blot or scratch it.
    Don't touch warning
  5. Make sure the jammed paper isn't under the ink holder. If you see paper under the holder, then move it to the right or left edge - whichever allows you to remove the paper.
    Note When you move the ink cartridge holder, slide it slowly.
    Cartridge being slowly moved
  6. Hold the jammed paper with both hands and pull it out slowly to avoid tearing.
    both hands pulling out jammed paper
  7. If the paper tore while attempting to remove the jam, a piece may remain in the printer. Check to see if any small pieces remain in the machine:
    • Check under the ink cartridge holder.
    • Check the right or the left side space (B) inside the machine. If any small pieces of paper remain in these spaces, remove them.
      Right and left side spaces inside the front cover
  8. Close the paper output cover, plug in the machine, and turn it back on.
  9. Reload the paper and begin your print job again.
  Note Be sure to use suitable paper and load it correctly. If the error message remains, there may still be paper in the machine.
If your product issue isn't resolved after following the steps above, your printer will require servicing.
There are two options currently available to you.
  1. Warranty Service – If you are within the 1-year manufacturer’s warranty and have your proof of purchase you are entitled to service or replacement. If you have purchased a CarePak Canon extended warranty, you may be entitled to additional options.  Please create or log into your Canon Account to obtain service.
  2. Out of Warranty – If you are outside of your warranty period, you may qualify for purchasing a replacement through the Canon Upgrade Program. Please contact our Sales group to inquire about your upgrade options at 866-443-8002.
To verify your support options please create or log into your Canon Account.
Powered by
