Choose paper suitable for printing, for the best print results. Canon provides you various types of paper to enhance the fun of printing, such as stickers as well as papers for photo or document. We recommend the use of Canon genuine paper for printing your important photos.
Media Types
Commercially available papers
Plain Paper (including recycled paper) *1
Envelopes *2
T-Shirt Transfers *2
Canon genuine papers
The Model Number of Canon genuine paper is shown in brackets. Refer to the instruction manual supplied with the paper for detailed information on the printable side and notes on handling paper. For information on the page sizes available for each Canon genuine paper, access our website.
You may not be able to purchase some Canon genuine papers depending on the country or region of purchase. Paper is not sold in the US by Model Number. Purchase paper by name.
Paper for printing documents:
Canon Red Label Superior <WOP111> *1
Canon Océ Office Colour Paper <SAT213> *1
Paper for printing photos:
Photo Paper Pro Platinum <PT-101>
Glossy Photo Paper "Everyday Use" <GP-501/GP-601>
Photo Paper Glossy <GP-601>
Photo Paper Plus Glossy II <PP-201> *1
Photo Paper Pro Luster <LU-101>
Photo Paper Plus Semi-gloss <SG-201>
Matte Photo Paper <MP-101> *2
Paper for printing business documents:
High Resolution Paper <HR-101N>
*1 This paper is also available for making copies. Select with the Paper button on the operation panel. You can select only A4 or Letter-sized plain paper or 4" x 6" (10 x 15 cm) photo paper..
*2 Printing to this paper from a PictBridge (Wireless LAN) compliant device is not supported.
Paper Load Limit
Page Sizes
You can use the following page sizes.
Only the following sizes may be printed from the operation panel.
- A4, Letter, and 4" x 6" (10 x 15 cm)
Printing on the following page sizes from a PictBridge (Wireless LAN) compliant device is not supported
- B5, A5, Legal, and Envelopes
Standard sizes:
Letter
Legal
A5
A4
B5
5" x 7" (13 x 18 cm)
8" x 10" (20 x 25 cm)
Envelope DL
Envelope Com 10
Non-standard sizes:
You can print on non-standard size paper within the following ranges.
Minimum size: 3.50 x 5.00 inches (89.0 x 127.0 mm)
Maximum size: 8.50 x 26.61 inches (215.9 x 676.0 mm)
Paper Weight
You can use paper in the following weight range.
17 to 28 lb (64 to 105 g /m2) (except for Canon genuine paper)
Do not use heavier or lighter paper (except for Canon genuine paper), as it could jam in the machine.
Notes on Storing Paper
Take out only the necessary amount of paper from the package just before printing.
To avoid curling, when you do not print, put unused paper back into the package and keep it on a level surface. And also, store it avoiding heat, humidity, and direct sunlight.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
