When art paper with 0.98 inch (25 mm) margins is selected, the printer is restricted from printing in the top and bottom 0.98 inch (25 mm) of the paper. We therefore recommend checking the printing area in the preview screen before printing.
If the print head is rubbing against the top of bottom edges of the paper, causing smudging, you can avoid this by using 0.98 inch (25 mm) margin paper.
Photo Paper Pro Premium Matte PM-101 and Matte Photo Paper MP-101 are printed to paper sizes with 0.98 inch (25 mm) margins depending on print settings. To print to other page sizes, remove restrictions on margins. For details, refer to the Online Manual.
A4/A3/A3+/A2/17" x 22" (43 x 56 cm)
Size | Recommended Printing Area (width x height) |
A4 (0.98 inch (25 mm) margin) | 8.00 x 9.72 inches (203.2 x 247.0 mm) |
A3 (0.98 inch (25 mm) margin) | 11.43 x 14.57 inches (290.2 x 370.0 mm) |
A3+ (0.98 inch (25 mm) margin) | 12.69 x 17.05 inches (322.2 x 433.0 mm) |
A2 (0.98 inch (25 mm) margin) | 16.27 x 21.42 inches (413.2 x 544.0 mm) |
17" x 22" (43 x 56 cm) (0.98 inch (25 mm) margin) | 16.73 x 20.03 inches (425.0 x 508.8 mm) |
Recommended printing area
A: 0.98 inch (25.0 mm)
B: 0.98 inch (25.0 mm)
C: 0.13 inch (3.4 mm)
D: 0.13 inch (3.4 mm)
Letter
Letter (0.98 inch (25 mm) margin) | 8.00 x 9.03 inches (203.2 x 229.4 mm) |
C: 0.25 inch (6.4 mm)
D: 0.25 inch (6.3 mm)
PRO-1000 Page
