Salesforce
Paper Load Limit - imagePROGRAF PRO-1000
« Go Back
Information
TitlePaper Load Limit - imagePROGRAF PRO-1000
URL NameART163219
Description
This article lists the paper load limits of the imagePROGRAF PRO-1000.
Solution
 When performing color calibration, load all types of paper in the top feed regardless of the paper sources shown in the tables below.
Commercially Available Papers
Media Name
Top Feed
Manual Feed Tray
Paper Output Tray
Plain Paper (including recycled paper) *1
Approx. 150 sheets
(20 sheets: A2)
N/A *2
Approx. 50 sheets
(20 sheets: A2)
Canon Genuine Papers
 We recommend that you remove the previously printed sheet from the paper output tray before continuously printing to avoid blurs and discoloration (except for Canon Red Label Superior <WOP111> and Canon Océ Office Colour Paper <SAT213>).
Paper for printing documents:
Media Name
Top Feed
Manual Feed Tray
Paper Output Tray
Approx. 120 sheets
N/A *2
Approx. 50 sheets
Approx. 100 sheets
N/A *2
Approx. 50 sheets
Paper for printing photos:
Media Name <Model No.>
Top Feed
Manual Feed Tray
Photo Paper Pro Platinum <PT-101*3
1 sheet: A2
10 sheets: A4, A3, A3+, Letter, 8" x 10" (20 x 25 cm)
20 sheets: 4" x 6" (10 x 15 cm)
1 sheet: A4, A3, A3+, A2, Letter, 8" x 10" (20 x 25 cm)
Photo Paper Plus Glossy II <PP-201*3
10 sheets: A4, A3, A3+, Letter, 5" x 7" (13 x 18 cm), 8" x 10" (20 x 25 cm)
1 sheet: A4, A3, A3+, Letter, 8" x 10" (20 x 25 cm)
Photo Paper Pro Luster <LU-101*3
1 sheet: A2, 17" x 22" (43 x 56 cm)
1 sheet: A4, A3, A3+, A2, Letter, 17" x 22" (43 x 56 cm)
Photo Paper Plus Semi-gloss <SG-201*3
1 sheet: 17" x 22" (43 x 56 cm)
1 sheet: A4, A3, A3+, Letter, 8" x 10" (20 x 25 cm), 17" x 22" (43 x 56 cm)
Matte Photo Paper <MP-101>
Photo Paper Pro Premium Matte <PM-101>
N/A *4
*1 Proper feeding of paper may not be possible at the maximum capacity depending on the type of paper or environmental conditions (either very high or low temperature or humidity). In such cases, reduce the number of paper you load at a time to less than half.
*2 Feeding paper from the manual feed tray can damage the printer. Always load in the top feed.
*3 When loading paper in stacks, the print side may become marked as it is fed or paper may not feed properly. In this case, load one sheet at a time.
*4 Feeding paper from the top feed can damage the printer. Always load in the manual feed tray.
 When using non-Canon genuine specialty paper, load one sheet at a time in the top feed or manual feed tray.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
Powered by
