Salesforce
How to Print the Network Configuration Page - MG8120
« Go Back
Information
TitleHow to Print the Network Configuration Page - MG8120
URL NameART164992
Description
This page is also known as the LAN Details page.
Solution
After your PIXMA MG8120 is connected to a network, you can print out a Network Configuration Page to show the status of the network connection between the printer and the router.
  1. From the HOME screen, use the up and down arrows until Setup appears.  Tap the function key underneath Setup.
  2. In the Setup menu, tap the right arrow until Device settings is selected.  Tap OK.
  3. In Device settings, tap the down arrow until LAN settings is selected.  Tap OK.
  4. In the LAN settings menu, tap the down arrow until Confirm LAN settings is selected.  Tap OK.
  5. Tap the down arrow to select Print LAN details.  Tap OK.
  6. On the confirmation message, Yes is highlighted by default.  Tap OK.
The Network Configuration Page will be printed.  An example of this page is attached below.
Powered by
