Placing a Printable Disc
To print onto a printable CD or DVD, place it on the disc tray supplied with the machine, then insert it into the machine.
This procedure also applies to printing from a computer.
Important
- Do not attach the disc tray until the message asking you to load the printable disc is displayed. Doing so can damage the machine.
Detach the disc tray from the cassette 1.
Note
- If a message is displayed on the screen after inserting the cassette into the machine, tap Register.
Holding both sides of the paper output tray (A), gently open it.
When the message asking you to load the printable disc is displayed, open the disc tray guide (B) and push it down all the way to the bottom.
Place the printable disc with the printable surface facing up.
Important
- Make sure that there is no dirt on the disc tray before placing a printable disc on the disc tray.
- When placing a printable disc on the disc tray, do not touch the printing surface of the disc or the reflectors (C) on the disc tray.
Attach the disc tray to the machine.
Note
- The disc tray may be ejected after a specified period of time has elapsed. In this case, follow the on-screen instructions to attach the disc tray.
Place the disc tray on the disc tray guide.
Insert the disc tray straight until the arrow (
) on the disc tray guide is almost aligned with the arrow (
) on the disc tray.
Important
- Do not insert the disc tray beyond the arrow (
) on the disc tray guide.
