Salesforce
Printing the Network Configuration Page - MG6120
« Go Back
Information
TitlePrinting the Network Configuration Page - MG6120
URL NameART165368
Description
This article will explain how to print the Network Configuration Page on the PIXMA MG6120.  An example of this page is attached below the article.
Solution
To print a Network Configuration Page, follow the steps below.
  1. From the HOME screen, tap the up or down arrows until Setup appears.  Press the function key under Setup.
  2. In the Setup menu, tap the right arrow until Device settings is selected.  Tap OK.
  3. In the Device settings menu, tap the down arrow until LAN settings is selected.  Tap OK.
  4. In the LAN settings menu, tap the down arrow until Confirm LAN settings is selected.  Tap OK.
  5. Tap the down arrow to select Print LAN details.  Tap OK.
  6. On the confirmation message, Yes will be highlighted.  Tap OK.
The Network Configuration Page will be printed.
Powered by
