WLAN setting list
The list of wireless LAN settings of this machine is displayed on the LCD.
The following setting items are displayed on the LCD and printed if Print LAN details was selected.
Items | Setting |
Connection | Active/Inactive |
SSID | XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX (up to 32 characters) |
Communication mode | Infrastructure |
Channel | XX (up to 2 digits) |
Wireless LAN security | Inactive/WEP(64bit)/WEP(128bit)/WPA-PSK(TKIP)/WPA-PSK(AES)/WPA2-PSK(TKIP)/WPA2-PSK(AES) |
Signal Strength | 0% - 99%
Note - When Print LAN details is selected, the signal strength will appear on the Network Configuration Page that was printed. This percentage will not appear on the LCD when WLAN setting list is selected.
IPv4 address | XXX. XXX. XXX. XXX (12 characters) |
IPv4 subnet mask | XXX. XXX. XXX. XXX (12 characters) |
IPv4 default gateway | XXX. XXX. XXX. XXX (12 characters) |
IPv6 address | XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX (32 characters) |
IPv6 subnet prefix length | XXX (up to 3 digits) |
IPv6 default gateway | XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX (32 characters) |
MAC address | XX:XX:XX:XX:XX:XX (12 characters) |
IPsec settings | Enable (ESP)/Enable (ESP & AH)/Enable (AH)/Disable |
Pre-shared key | XXXXXXXXXXXXXXXX (16 characters) |
Printer name | XXXXXXXXXXXXXXX (up to 15 characters) |
Bonjour service name | XXXXXXXXXXXXX XXXXXXXXXXXXX XXXXXXXXXXXXX XXXXXXXXXXXXX (up to 52 characters) |
("XX" represents alphanumeric characters.)
