1. Press the HOME button (A) on the printer.
2. Use the Up / Down keys to select LAN settings, then press the OK button.
3. Select Wireless LAN setup, then press the OK button.
Select Cableless setup and press the OK button.
Press the OK button.
Once Cableless Setup has been initiated on the printer, you still need to install the drivers and software to enable the printer to be used over the wireless network. Please open the appropriate attachment for software installation information .
