Salesforce
Print the Network Settings (LAN details) - iB4120
« Go Back
Information
TitlePrint the Network Settings (LAN details) - iB4120
URL NameART166374
Description
This article explains how to print a Network Settings (also known as LAN Details) page.
Solution
Use the operation panel to print the printer's current network settings.
 The network settings printout contains important information about your network. Handle it with care.
  1. Make sure the printer is powered on.
  2. Load three sheets of A4 or Letter-sized plain paper.
  3. Press the Setup button.
    The Setup menu screen appears.
  4. Select Device settings and press the OK button.
  5. Select LAN settings and press the OK button.
  6. Select Print LAN details and press OK button.
    The printer starts printing network settings information.
    The printed network settings information is as follows:
    Item
    Description
    Setting
    Product Information
    Product information
    Product Name
    Product name
    XXXXXXXX
    ROM Version
    ROM version
    XXXXXXXX
    Serial Number
    Serial number
    XXXXXXXX
    Wireless LAN
    Wireless LAN
    Enable/Disable
    MAC Address
    MAC address
    XX:XX:XX:XX:XX:XX
    Infrastructure
    Infrastructure
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Wireless LAN SSID
    Channel *1
    Channel
    XX (1 to 11)
    Encryption
    Encryption method
    None/WEP/TKIP/AES
    WEP Key Length
    WEP key length (bits)
    Inactive/128/64
    Authentication
    Authentication method
    None/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal strength
    0 to 100 [%]
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    Link Local Address
    Link local address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Link Local Prefix Length
    Link local prefix length
    XXX
    Manual Setting
    Manual setting
    Enable/Disable
    IP Address *2
    IP address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Subnet Prefix Length
    Subnet prefix length
    XXX
    Stateless Address1 *2
    Stateless address 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length 1 *2
    Stateless prefix length 1
    XXX
    Stateless Address2 *2
    Stateless address 2
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length2 *2
    Stateless prefix length 2
    XXX
    Stateless Address3 *2
    Stateless address 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length3 *2
    Stateless prefix length 3
    XXX
    Stateless Address4 *2
    Stateless address 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length4 *2
    Stateless prefix length 4
    XXX
    Default Gateway1 *2
    Default gateway 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway2 *2
    Default gateway 2
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway3 *2
    Default gateway 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway4 *2
    Default gateway 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPsec *3
    IPsec setting
    Active
    Security Protocol *3
    Security method
    ESP/ESP & AH/AH
    Direct Connection
    Direct connection
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Direct Connection SSID
    Password
    Password
    Direct Connection password (10 alphanumeric characters)
    Channel
    Channel
    3
    Encryption
    Encryption method
    AES
    Authentication
    WPA2-PSK
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    Link Local Address
    Link local address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Subnet Prefix Length *2
    XXX
    IPsec *3
    IPsec setting
    Active
    Security method
    Wired LAN
    Wired LAN
    Enable/Disable
    MAC Address
    MAC address
    XX:XX:XX:XX:XX:XX
    Connection
    Wired LAN status
    Active/Inactive
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    Link Local Address
    Link local address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Manual Setting
    Manual setting
    Enable/Disable
    IP Address *2
    IP address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Stateless address 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length1 *2
    XXX
    Stateless address 2
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Stateless address 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Stateless address 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Default Gateway1 *2
    Default gateway 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway2 *2
    Default gateway 2
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway3 *2
    Default gateway 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway4 *2
    Default gateway 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPsec *3
    IPsec setting
    Active
    Security method
    ESP/ESP & AH/AH
    Wired LAN DRX
    Discontinuous reception (wired LAN)
    Enable/Disable
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 alphanumeric characters)
    Direct Conn. DevName
    Device name for direct connection (Up to 32 characters)
    WSD Printing
    WSD printing setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPD Printing
    LPD printing setting
    Enable/Disable
    RAW Printing
    RAW printing setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 alphanumeric characters)
    LLMNR
    LLMNR setting
    Enable/Disable
    SNMP
    SNMP setting
    Enable/Disable
    DNS Server
    Obtain DNS server address automatically
    Auto/Manual
    Primary Server
    Primary server address
    XXX.XXX.XXX.XXX
    Secondary Server
    Secondary server address
    XXX.XXX.XXX.XXX
    Proxy Server
    Proxy server setting
    Enable/Disable
    Proxy Address
    Proxy address
    XXXXXXXXXXXXXXXXXXXX
    Proxy Port
    Proxy port specification
    1 to 65535
    Cert. Fingerprt(SHA-1)
    Certificate fingerprint(SHA-1)
    XXXXXXXX XXXXXXXX XXXXXXXX
    XXXXXXXX XXXXXXXX
    Cert. Fingerprt(SHA-256)
    Certificate fingerprint(SHA-256)
    XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
    ("XX" represents alphanumeric characters.)
    *1 Channel may range from 1 to 11 depending on country or region of purchase.
    *2 Network status is only printed when IPv6 is enabled.
    *3 Network status is only printed when IPv6 and IPsec settings are enabled.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
