Salesforce
Wired LAN Sheet - IJ Network Tool (Windows)
« Go Back
Information
TitleWired LAN Sheet - IJ Network Tool (Windows)
URL NameART166683
Description
Wired LAN Sheet (Windows)
Solution
Allows you to set the printer with wired LAN connection.
To display the Wired LAN sheet, click the Wired LAN tab on the Configuration screen.
  1. TCP/IP Setup:
    Sets the IP address of the printer to be used over the LAN. Specify a value appropriate for your network environment.
    Get IP address automatically
    Select this option to use an IP address automatically assigned by a DHCP server. DHCP server functionality must be enabled on your router.
    Use next IP address
    Select this option if no DHCP server functionality is available in your setup where you use the printer, or you want to use a particular IP address or a fixed IP address.
Powered by
