Salesforce
Changing Settings in Admin Password Sheet (Windows)
« Go Back
Information
TitleChanging Settings in Admin Password Sheet (Windows)
URL NameART166684
Description
Learn about changing settings in the Admin Password Sheet in IJ Network Tool for Windows.
Solution
 You cannot change the settings when using the direct connection (access point mode).
  1. Start up IJ Network Tool.
  2. Select the printer in Printers:.
  3. Select Configuration... on Settings menu.
  4. Click Admin Password tab.
    The Admin Password sheet is displayed.
    For more on the Admin Password sheet, see Admin Password Sheet.
  5. Change or check settings.
    To use an administrator password, select the Use admin password check box and enter a password.
     The password should consist of 4 to 32 alphanumeric characters. The password is case-sensitive. Do not forget the password you set. If you forget the administrator password you specified, initialize the printer to return the password to the default setting.
  6. Click OK.
    A screen is displayed asking you for confirmation before the settings are sent to the printer. If you click Yes, the settings are sent to the printer and the Transmitted Settings screen is displayed.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
