Salesforce
Changing Settings in Direct Connection (Windows)
« Go Back
Information
TitleChanging Settings in Direct Connection (Windows)
URL NameART166687
Description
Solution
 Note
  • This function is not available depending on the printer you are using.
  • Depending on the printer you are using, "Direct connection" may be referred to as "Access point mode" in the manuals.
  • You can use this function only when you are using a computer compatible with the wireless LAN.
  1. Start up IJ Network Tool.
  2. Select Set up printer's direct connection... in the Settings menu.
    The Direct Connection Setup of the Printer screen is displayed.
  3. Check displayed message and click Next>.
  4. If the User Account Control screen is displayed, click Yes.
    The Select Printer screen is displayed.
     Note
    • If only one printer is available for changing the settings, the Direct Connection Setup of the Printer screen is displayed. In this case, go to step 6.
  5. Select the printer from the Select Printer screen and click OK.
    The specified SSID (access point name), encryption method, and password are displayed on the Select Printer screen.
  6. Change encryption method or password as necessary.
     Important
    • You cannot change the encryption method or password depending on the printer you are using.
    • If you cannot change the settings from the screen above, you can update the SSID (access point name) and password at the same time using the operation panel (You cannot change the encryption method.).
  7. Click Settings.
    The setting information is sent to the printer.
Powered by
