Salesforce
How to Start Cableless Setup - iP8720
« Go Back
Information
TitleHow to Start Cableless Setup - iP8720
URL NameART166929
Description
This article explains how to place your PIXMA iP8720 into cableless setup mode.
Solution
To place your printer into cableless setup mode, follow the steps below.
  1.  Hold down the Wi-Fi button (B) on the printer until the (white) POWER lamp flashes 2 times, then release the Wi-Fi button after the second flash.
  2. Make sure that the (blue) Wi-Fi lamp flashes quickly and the (white) POWER lamp is lit.
The printer is now in cableless setup mode.  Proceed with installing the software on your computer or using Canon PRINT Inkjet / SELPHY for iOS or Android to connect the printer to your wireless network.
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
Powered by
