Salesforce
Printing the Network Settings (LAN details) - TS5020
« Go Back
Information
TitlePrinting the Network Settings (LAN details) - TS5020
URL NameART166939
Description
This article explains how to print the Network Configuration Page (also know as LAN details) for your PIXMA TS5020.  An example of this page is attached to this article.
Solution
Printing Network Settings
Use the operation panel to print the printer's current network settings.
Important
  • The network settings printout contains important information about your network. Handle it with care.
  1. Make sure printer is turned on.
    If the HOME screen is not displayed, press the HOME button.
  2. Load three sheets of A4 or Letter-sized plain paper.
  3. Select    (Network status) icon.
    The menu screen appears.
  4. Check the message and select Yes.
  5. Select Print details.
  6. Select Yes.
    The printer starts printing network settings information.
    The printed network settings information is as follows: (Some setting values are not displayed depending on the printer settings.)
    Item
    Description
    Setting
    Product Information
    Product information
    Product Name
    Product name
    XXXXXXXX
    ROM Version
    ROM version
    XXXXXXXX
    Serial Number
    Serial number
    XXXXXXXX
    Wireless LAN
    Wireless LAN
    Enable/Disable
    MAC Address
    MAC address
    XX:XX:XX:XX:XX:XX
    Infrastructure
    Infrastructure
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Wireless LAN SSID
    Channel
    Channel
    XX (1 to 11)
    Encryption
    Encryption method
    None/WEP/TKIP/AES
    WEP Key Length
    WEP key length (bits)
    Inactive/128/64
    Authentication
    Authentication method
    None/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal strength
    0 to 100 [%]
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    Link Local Address
    Link local address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Link Local Prefix Length
    Link local prefix length
    XXX
    Stateless Address1
    Stateless address 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length1
    Stateless prefix length 1
    XXX
    Stateless Address2
    Stateless address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length2
    Stateless prefix length 2
    XXX
    Stateless Address3
    Stateless address 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length3
    Stateless prefix length 3
    XXX
    Stateless Address4
    Stateless address 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Stateless Prefix Length4
    Stateless prefix length 4
    XXX
    Default Gateway1
    Default gateway 1
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway2
    Default gateway 2
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway3
    Default gateway 3
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Default Gateway4
    Default gateway 4
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPsec
    IPsec setting
    Active
    Security Protocol
    Security method
    ESP/ESP & AH/AH
    Wireless Direct
    Wireless direct
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Wireless Direct SSID
    Password
    Password
    Wireless Direct password (10 alphanumeric characters)
    Channel
    Channel
    3
    Encryption
    Encryption method
    AES
    Authentication
    WPA2-PSK
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    Link Local Address
    Link local address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    IPsec
    IPsec setting
    Active
    Security Protocol
    Security method
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 alphanumeric characters)
    Direct Conn. DevName
    Device name for wireless direct (Up to 32 characters)
    WSD Printing
    WSD printing setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPD Printing
    LPD printing setting
    Enable/Disable
    RAW Printing
    RAW printing setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 alphanumeric characters)
    LLMNR
    LLMNR setting
    Enable/Disable
    SNMP
    SNMP setting
    Enable/Disable
    PictBridge Commun.
    PictBridge communication
    Enable/Disable
    DNS Server
    Obtain DNS server address automatically
    Auto/Manual
    Primary Server
    Primary server address
    XXX.XXX.XXX.XXX
    Secondary Server
    Secondary server address
    XXX.XXX.XXX.XXX
    Proxy Server
    Proxy server setting
    Enable/Disable
    Proxy Address
    Proxy address
    XXXXXXXXXXXXXXXXXXXX
    Proxy Port
    Proxy port specification
    1 to 65535
    Cert. Fingerprt(SHA-1)
    Certificate fingerprint(SHA-1)
    XXXXXXXX XXXXXXXX XXXXXXXX
    XXXXXXXX XXXXXXXX
    Cert. Fingerprt(SHA-256)
    Certificate fingerprint(SHA-256)
    XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
    ("XX" represents alphanumeric characters.)
TS5020 Page
Powered by
