Salesforce
Start the Wi-Fi Connection Assistant (Windows)
« Go Back
Information
TitleStart the Wi-Fi Connection Assistant (Windows)
URL NameART166949
Description
Wi-Fi Connection Assistant allows you to diagnose or repair the network status, and to perform printer settings on network.
This article explains how to start the Windows version of the Wi-Fi Connection Assistant.
Solution
Before Starting
These instructions are for the Windows version of this program. The instructions assume you already have this program installed.
If you don't have the Wi-Fi Connection Assistant installed, the latest version can be downloaded from here.
If you have a Mac, the instructions for the macOS version of Wi-Fi Connection Assistant can be found here.
Start up Wi-Fi Connection Assistant for Windows as shown below.
  • In Windows 11, click the Start button, select All, Canon Utilities, and then Wi-Fi Connection Assistant.
  • In Windows 10, click the Start button, select All apps, Canon Utilities, and then Wi-Fi Connection Assistant.
  • In Windows 8.1 or Windows 8, select Wi-Fi Connection Assistant on the Start screen to start Wi-Fi Connection Assistant. If Wi-Fi Connection Assistant is not displayed on the Start screen, select the Search charm and search for "Wi-Fi Connection Assistant".
  • In Windows 7 or Windows Vista, click Start and select All Programs, Canon Utilities, Wi-Fi Connection Assistant, and then Wi-Fi Connection Assistant.
Powered by
