Printing Network Settings
Use the operation panel to print the printer's current network settings.
Important
- The network settings printout contains important information about your network. Handle it with care.
Make sure printer is turned on.
Load two sheets of A4 or Letter-sized plain paper.
Press Setup button.
The Setup menu screen appears.
Select Device settings and press OK button.
Select LAN settings and press OK button.
Select Print LAN details and press OK button.
The printer starts printing network settings information.
The printed network settings information is as follows: (Some setting values are not displayed depending on the printer settings.)
Item | Description | Setting |
Product Information | Product information | – |
Product Name | Product name | XXXXXXXX |
ROM Version | ROM version | XXXXXXXX |
Serial Number | Serial number | XXXXXXXX |
Wireless LAN | Wireless LAN | Enable/Disable |
Infrastructure | Infrastructure | Enable/Disable |
MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
Connection | Connection status | Active/Inactive |
SSID | SSID | Wireless LAN SSID |
Channel | Channel | XX (1 to 11) |
Encryption | Encryption method | None/WEP/TKIP/AES |
WEP Key Length | WEP key length (bits) | Inactive/128/64 |
Authentication | Authentication method | None/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal strength | 0 to 100 [%] |
TCP/IPv4 | TCP/IPv4 | Enable |
IP Address | IP address | XXX.XXX.XXX.XXX |
Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
TCP/IPv6 | TCP/IPv6 | Enable/Disable |
Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Link Local Prefix Length | Link local prefix length | XXX |
Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
Stateless Address2 | Stateless address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
IPsec | IPsec setting | Active |
Security Protocol | Security method | ESP/ESP & AH/AH |
Wireless Direct | Wireless direct | Enable/Disable |
SSID | SSID | Wireless Direct SSID |
Password | Password | Wireless Direct password (10 alphanumeric characters) |
Channel | Channel | 3 |
Encryption | Encryption method | AES |
Authentication | Authentication method | WPA2-PSK |
Security Protocol | Security method | – |
Other Settings | Other settings | – |
Printer Name | Printer name | Printer name (Up to 15 alphanumeric characters) |
Wireless Direct DevName | Device name for wireless direct (Up to 32 characters) | Device name for wireless direct |
WSD Printing | WSD printing setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LPD Printing | LPD printing setting | Enable/Disable |
RAW Printing | RAW printing setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 alphanumeric characters) |
LLMNR | LLMNR setting | Enable/Disable |
SNMP | SNMP setting | Enable/Disable |
DNS Server | Obtain DNS server address automatically | Auto/Manual |
Primary Server | Primary server address | XXX.XXX.XXX.XXX |
Secondary Server | Secondary server address | XXX.XXX.XXX.XXX |
Proxy Server | Proxy server setting | Enable/Disable |
Proxy Address | Proxy address | XXXXXXXXXXXXXXXXXXXX |
Proxy Port | Proxy port specification | 1 to 65535 |
Cert. Fingerprt(SHA-1) | Certificate fingerprint (SHA-1) | XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX |
Cert. Fingerprt(SHA-256) | Certificate fingerprint (SHA-256) | XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX |
("XX" represents alphanumeric characters.)
