Wireless Connection
Prior to starting setup on the Computer, Smartphone or tablet device, start the Easy wireless connect on the printer. Then complete the setup on the computer or device.
See the procedure below to start the Easy Wireless connect.
Make sure that the printer is turned on.
If the power is on, the POWER lamp (A) will be lit.
(Appears in a new window)
If the printer is performing cleaning, print head alignment, or other processes
Wait for the process to finish, before starting setup.
If
is displayed on the left side of the screen, tap
If an error screen is displayed, tap OK, then tap
Tap
(B).
Tap LAN settings.
Tap Wireless LAN.
Tap Wireless LAN setup.
Tap Easy wireless connect.
Tap Yes.
When the printer preparation is complete, the screen below appears.
Return to the setup application screen and proceed with the setup.
TS8020 Page
