You can connect to the printer wirelessly from a computer or mobile device (even without a wireless router). Search for "Wireless Direct" in the
Canon Knowledge Base or find instructions for your specific printer in the
Canon Manual Library.
When you connect a new device to your printer, use the connection method used for the previous device(s); otherwise, the connected device(s) will be disabled.
Connect via wireless router
Make sure your device and the wireless router are connected. See the router manual for details.
Configuration, router functions, setup procedures and security settings of network devices vary depending on the system environment. See the router manual for details.
These printers don't support IEEE802.11ac, IEEE802.11a, or IEEE802.11n (5 GHz). Check if your device supports IEEE802.11n (2.4 GHz), IEEE802.11g or IEEE802.11b.
If your device is set to the "IEEE802.11n only" mode, WEP or TKIP can't be used as a security protocol. Change the security protocol to something other than WEP and TKIP, or change the setting to something other than "IEEE802.11n only." The router / device connection temporarily disables if you change settings.
For office use, consult your network administrator.
If you connect to a network with no security protection, your personal information could be disclosed to a third party.
Wireless Direct mode
Your mobile device can use Wi-Fi® to communicate with the printer and still use mobile data for other tasks.
Charges may apply when you connect to the Internet using a mobile data connection.
When you use Wireless Direct to connect your printer and router, the Wi-Fi settings are saved. This means your device may automatically connect to the printer. To prevent this, change the connection mode after you use the printer, or set your device's Wi-Fi settings to block automatic connection.
To check or change wireless router settings, see the router manual.
If you connect a device and the printer via Wireless Direct and lose the connection to the Internet, web services for the printer are unavailable.
You can connect up to five devices to the printer with Wireless Connect. If you connect a sixth device, an error will appear.
Devices connected to the printer via Wireless Direct can't communicate with each other.
Firmware updates for the printer aren't available when you use Wireless Direct.
If you connect a device to the printer without using a router, then disconnect the device, you will need to go to the Wi-Fi setting screen to disable the connection before you can reconnect the device.
