Salesforce
Paper Load Limit - TS3120 / TS3122
« Go Back
Information
TitlePaper Load Limit - TS3120 / TS3122
URL NameART167902
Description
This article lists the load limits for various media types that can be used with the PIXMA TS3120 / TS3122.
Solution
Genuine Canon Paper
Paper for printing documents:
Media Name <Model No.>Rear TrayPaper Output Tray
Canon Red Label Superior <WOP111>Approx. 60 sheetsApprox. 10 sheets
Canon Océ Office Colour Paper <SAT213>Approx. 50 sheetsApprox. 10 sheets
Paper for printing photos:
 Note
  • For best results in continuous printing, remove printed sheets from the paper output tray to avoid smearing or discoloration.
Glossy Photo Paper "Everyday Use" <GP-501>*1
5" x 7" (13 x 18 cm), Square 5" x 5" (127 x 127 mm): 10 sheets
4" x 6" (10 x 15 cm): 20 sheets
*2
Photo Paper Glossy <GP-701>*1
*2
Photo Paper Plus Glossy II <PP-201>*1
*2
Photo Paper Plus Glossy II <PP-301>*1
*2
Paper other than Genuine Canon Paper
Common NameRear TrayPaper Output Tray
Plain Paper (including recycled paper)*3Approx. 60 sheets (10 sheets: Legal)Approx. 10 sheets
  • *1 Feeding from a loaded stack of paper may leave marks on the printed side or prevent efficient feeding. In this case, load one sheet at a time.
  • *2 For best results in continuous printing, remove printed paper from the paper output tray to avoid smearing or discoloration.
  • *3 Normal feeding at maximum capacity may not be possible with some types of paper, or under very high or low temperature or humidity. In this case, load half the amount of paper or less.
PIXMA TS3120 / TS3122 Page
Powered by
