Turn the printer ON. If the printer is performing cleaning, print head alignment, or another process, wait for it to finish.
Tap the Network Status button (A) on the printer.
Tap LAN settings on the Basic network information screen.
Tap Wireless LAN.
Tap Wireless Lan setup.
Tap Easy Wireless Connect, then tap Yes.
When the printer preparation is complete, you will see this screen:
Return to the setup application screen and continue with the setup.
2 Download and run the setup file on your computer
First you will need to get the setup file (set up can also be performed by using the Setup CD-ROM).
Read the information and note how to run the setup file. If set up doesn't start automatically, click the Download button.
Select Start Setup on the first screen.
Select the region where you live, then Next.
Select Yes on the license agreement.
Select Agree or Do Not Agree to the survey, then Next.
Select Yes on the Connection Method screen.
Setup continues. If the Select wireless router screen (below) appears, select the wireless router to connect to the printer, enter the Network Key (password) and select Next. The screen below may not appear. If it doesn't, go to the next step.
The network connection is complete. Select Next.
The drivers will install. Select Start to print a test page or Next to continue.
Select Next from the Setup Complete page.
Select any optional application software desired. Select Next.
Select Next.
Select Exit and your setup is complete.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
