Salesforce
Remote Reception
« Go Back
Information
TitleRemote Reception
URL NameART168074
Description
TR8520
Solution
Remote Reception
If the printer is located away from the telephone, pick up the handset of the telephone connected to the printer and dial 25 (the remote reception ID) to receive faxes (remote reception).
  • If you use a rotary pulse line, temporarily switch your telephone to tone dialing. For details on how to switch to tone dialing, refer to your telephone's instruction manual.
  • If you have an answering device connected to the printer that can carry out remote control operations, the security code for this function may be the same as the remote reception ID. In this case, change the remote reception ID in Remote RX ID in Remote RX in Advanced FAX settings under FAX settings.
Powered by
