Solution | Settings on PictBridge (Wireless LAN) Compliant DeviceThis section describes the PictBridge (Wireless LAN) function of the printer. For the print settings on a PictBridge (Wireless LAN) compliant device, refer to the instructions given in the device's instruction manual.
Note
In the following description, names of setting items are given according to those used in Canon-brand PictBridge (Wireless LAN) compliant devices. Setting item names may be different depending on the brand or model of your device. -
Some setting items explained below may not be available on some devices. In this case, the settings made on the printer are applied. Also, when some items are set to Default on a PictBridge (Wireless LAN) compliant device, the printer settings for these items are applied.
The following settings can be used when printing from a PictBridge (Wireless LAN) compliant device.
Paper size | 4" x 6"/ 10 x 15 cm, 5" x 7"*1, Square 5"x5" 127x127mm*1*2, 8" x 10"/ 20 x 25 cm, A4, 8.5" x 11"(Letter) *1 Can be selected only on certain Canon-brand PictBridge (Wireless LAN) compliant devices. (May not be selected depending on the device.) *2 Size name may differ depending on the PictBridge (Wireless LAN) compliant devices. | Paper type | -
Default: Glossy Photo Paper "Everyday Use" GP-501/GP-701/Photo Paper Plus Semi-gloss SG-201/Photo Paper Pro Luster LU-101/Matte Photo Paper MP-101 -
Photo: Photo Paper Plus Glossy II PP-201/PP-301/Photo Stickers* * When printing on sticker paper, select 4"x6"/10x15cm in Paper size. Do not set Layout to Borderless. -
Fast Photo: Photo Paper Pro Platinum PT-101 -
Plain: A4/Letter sized plain paper When Paper type is set to Plain, borderless printing will be disabled even when Layout is set to Borderless. | Layout | Default (Selections based on the printer setting), Index, Bordered, Borderless, N-up (2, 4, 9, 16)*1, 20-up*2, 35-up*3 *1 Layout compatible with A4 or Letter-sized paper and Canon-brand sticker above. -A4/Letter: 4-up -Photo Stickers: 2-up, 4-up, 9-up, 16-up. *2 With a Canon brand PictBridge (Wireless LAN) compliant device, selecting items with "i" mark allows you to print shooting info (Exif Data) in list format (20-up) or on the margins of the specified data (1-up). (May not be available with some Canon-brand PictBridge (Wireless LAN) compliant devices.) *3 Printed in 35 mm Film Style Layout (Contact Printing Layout). Available only with a Canon-brand PictBridge (Wireless LAN) compliant device. (May not be available with some Canon-brand PictBridge (Wireless LAN) compliant devices.) | Print date & file no. | Default (Off: No printing), Date, File No., Both, Off | Image optimize | Default (Selections based on the printer setting), On (Auto photo fix)*1, Off, Red-Eye*2 *1 The scene or person's face of a shot photo is recognized and the most suitable correction for each photo is made automatically. It makes a darkened face by backlight brighter to print. It also analyzes a scene such as scenery, night scene, person, etc. and corrects each scene with the most suitable color, brightness, or contrasts automatically to print. *2 Can be selected only on certain Canon-brand PictBridge (Wireless LAN) compliant devices. (May not be selected depending on the device.) | Trimming | Default (Off: No trimming), On (follow the camera's setting), Off | Settings on PrinterYou can change the PictBridge (Wireless LAN) print settings from the PictBridge print settings screen. Set the print settings to Default on the PictBridge (Wireless LAN) compliant device when you want to print according to the settings on the printer. This section describes the procedure to display the PictBridge print settings screen. -
Make sure that the printer is turned on. -
Select
Setup on the HOME screen. -
Select
Settings. -
Select
Device settings. -
Select PictBridge print settings. -
Check the message that is displayed and select OK. The PictBridge print settings screen is displayed. For more on the setting available :
TS6120 Page |
