Using Caller ID Service to Reject Calls
If you subscribe to the Caller ID service, the printer detects the sender's Caller ID. If the sender's ID matches the condition specified in this setting, the printer rejects the phone call or fax reception from the sender.
Note
Specify the setting following the procedure below.
Make sure that printer is turned on.
Select
Setup on the HOME screen.
Select
Settings.
Select
Device settings.
Select FAX settings.
Select Security control.
Select Caller rejection.
Select Yes.
The Caller rejection conditions screen is displayed.
Specify rejection conditions.
Select a setting item and select Accept or Reject.
- Anonymous no.
- Selects whether to reject a phone call or fax reception from an anonymous number.
- Out of area no.
- Selects whether to reject a phone call or fax reception out of the subscribed service area.
- Rejected numbers
- Selects whether to reject a phone call or fax reception from the specified numbers.
Select OK to finish specifying rejection conditions.
If you select Reject for Rejected numbers, Register rejected numbers? is displayed on the touch screen. Select Yes, and then register the rejected number.
For details on how to register the rejected number, see Registering Rejected Number.
Note
Even if you select Reject, the printer rings once.
(The printer may not ring depending on the country or region of purchase.)
TR8520 Page
