Salesforce
ECO settings - TR8520
« Go Back
Information
TitleECO settings - TR8520
URL NameART168120
Description
Energy Saving, Green
Solution
ECO settings
This setting allows you to use automatic duplex printing as a default to save paper and to turn on/off the printer automatically to save electricity.
Using Duplex Printing
Follow the procedure below to use duplex printing.
  1. Make sure printer is turned on.
  2. Select   Setup on the HOME screen.
  3. Select   Settings.
  4. Select   ECO.
  5. Select Two-sided printing setting.
  6. Specify settings as necessary.
    figure: Touch screen
    1. Select two-sided copying as a default.
    2. Select two-sided printing of PDF files saved on a memory card as a default.
    3. Select two-sided printing of sent/received faxes, reports, or lists as a default.
    4. Select two-sided printing of template forms on the printer as a default.
Using Power Saving Function
Follow the procedure below to use power saving function.
  3. Select   Settings.
  4. Select   ECO.
  5. Select Energy saving settings.
  6. Check on-screen instructions and select Next.
  7. Specify settings as necessary.
    1. Specify the length of time to turn the printer off automatically when no operation is made or no printing data is sent to the printer.
    2. Selecting ON enables the printer to turn on automatically when a scanning** command  or printing data is sent to the printer.
      **Scanning with compatible iOS or Android devices requires the Canon PRINT Inkjet / SELPHY application
TR8520 Page
Powered by
