To reach the Feed settings for your printer, follow these steps.
From the HOME screen, tap the Setup
icon.
Tap Settings
Tap Device settings
Scroll down to Feed settings and tap it.
Feed settings
By registering the paper size and the media type loaded on the rear tray or in the cassette, you can prevent the printer from misprinting by displaying the message before printing starts when the paper size or the media type of the loaded paper differs from the print settings.
For details:
Register paper information
Registers the paper size and the media type you load on the rear tray and in the cassette.
Note
Detect paper setting mismatch
If you select Yes, the printer detects whether the paper size and the media type are identical with those registered in Register paper information. If printing starts with the settings that do not match, an error message is displayed on the touch screen.
Note
Check paper replacement
If you select Yes, the printer detects the paper replacement (the feed slot cover is opened or closed, the cassette is reinserted). When the paper registration screen is displayed after replacing paper, register the paper size and the media type.
TR8520 Page
