The instructions below show how to use the Easy Wireless Connect method to print and scan wirelessly.
The PIXMA TS3120 / TS3122 printers must be connected to the wireless network and the correct software must be installed on the computer.
The setup process consists of 2 parts:
- Start Easy Wireless Connect.
- Download and run the setup files.
1. Start Easy Wireless Connect on the printer
If the ON lamp (A) on the printer is flashing, tap Stop (B).
Press and hold the direct button (C) on the printer, and then release the button when
(D) flashes.
Make sure
and the horizontal bars (E) flash as shown.
Proceed to the setup application screen to continue setup.
2. Download and run the setup files
Follow the link to get the setup file, once you find the file you need tap Download. After the files have downloaded, follow the steps below to complete the setup process.
If you see a message like this:
Select OK. Then, control-click on the setup file, select Open, then select Open in the error message window. This will allow the setup program to proceed.
Start setup. Tap Next.
Enter your computer User Name and Password then select Install Helper.
Select Start Setup.
Select appropriate region and tap Next.
Select Yes on the License Agreement.
Select Agree or Do Not Agree to the Survey.
Status check occurs.
Select Yes on the Connection Method.
Setup continues. If the Select wireless router screen (below) appears, select the router to use and enter the Network Key (password) and tap Next.
The router being used and its network settings determines whether or not this screen appears.
Network connection completed. Tap Next.
If your printer is not detected, make sure that the computer has reconnected to the correct network. Also, you may need to temporarily disable any firewall software, or you may need to open blocked ports in the firewall. If your Mac is connected to a VPN (Virtual Private Network), temporarily disconnect from the VPN and try the setup again. Also, if you are using a dual-band router, further troubleshooting information can be found here.
IJ Scan Utility Lite will be installed. This may take several minutes.
If the following message appears, select Allow.
Tap Add Printer on the Add Printer screen.
On the Add screen, select the TS3100 series with Bonjour Multifunction listed in the Kind column. Select AirPrint or Secure AirPrint from the dropdown list in the Use box. Tap Add.
Tap Next.
Tap Next.
Setup complete. Tap Next.
Select any optional application software desired. Tap Next.
Tap Next.
Select Next or Skip.
Tap Exit.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
PIXMA TS3120 / TS3122 Page
