Salesforce
Placing a Printable Disc - TS8120
« Go Back
Information
TitlePlacing a Printable Disc - TS8120
URL NameART168395
Description
Solution
To print onto a printable disc, place it on the disc tray supplied with the printer, then insert it into the printer.
This procedure also applies to printing from a computer.
 Important
  • Do not attach the disc tray until the message asking you to load the printable disc is displayed. Doing so can damage the printer.
  1. When the message asking you to load the printable disc is displayed, open the operation panel (A), and then pick out the disc tray from the disc tray storage compartment (B).
  2. Place the printable disc with the printable surface facing up.
     Important
    • Make sure that there is no dirt on the disc tray before placing a printable disc on the disc tray.
    • When placing a printable disc on the disc tray, do not touch the printing surface of the disc or the reflectors (C) on the disc tray.
  3. Place the disc tray on the disc tray guide.
     Note
    • The disc tray may be ejected after a specified period of time has elapsed. In this case, follow the on-screen instructions to attach the disc tray.
  4. Insert the disc tray straight until the white line on the disc tray guide is almost aligned with the arrow ( ) on the disc tray.
     Important
    • Do not insert the disc tray beyond the white line on the disc tray guide.
TS8120 Page
Powered by
